Read Door Sensor and motion status via local network
Hinweis für Entwickler
  • Hi, how can i get door sensor status and motion sensor status through local network and use it for script.
    what i want to do is, when the door sensor is open, turn shelly 2pm relay on. when door sensor is close, shelly 2 pm add a script to check if there is motion from motion sensor. if there is a motion, keep the relay on. else, turn the relay off. i want to do it all locally without internet connection.
    thanks
  • sangwilly 6. März 2023 um 12:31
    Hat den Titel des Themas von „Red Door Sensor and motion status via local network“ zu „Read Door Sensor and motion status via local network“ geändert.
  • this is possible, but you'd need advanced Javascript skills in order to to this.
    - create a scripting based HTTPServer
    - use actions from the DW2 to write the open/close status to that webserver
    - store open/close status in scripting based KVS (key value storage)
    - use actions from the motion sensor to write motion status to the the HTTPServer
    - store motion status in the KVS.
    periodically check the KVS values and turn on/off the relay based on those values.
    please check the scripting documentation for detailed infos.
    https://shelly-api-docs.shelly.cloud/gen2/Scripts/S…anguageFeatures
