Custom script with standalone Shelly Uni?
  • Hello, new to Shelly and trying to understand if a Shelly Uni can do what I want. The short question is: Is it possible to run custom scripts (ex. mJs) on the Shelly Uni?
    The slightly longer question is: I want to connect two temperature sensors to the Uni, and based on the temperatures I want to toggle a water valve between two positions.
    I want this to be a standalone solution so I want no Home Assistant or other home automation server.
    If custom scripts can't be run directly on the Uni, would it be possible to possible if I added eg. a Shelly Plus device and run the script on that device and only use the Uni for I/O?
    Thankful for any help!
