Shelly watchdog - restart
Hinweis für Entwickler
  • Hi,
    at first I wanted to say, I'm not a coder by any means ;)
    So my goal is to have a script which checks if a Shelly is able to reach the Internet and if not, Shelly should be restarted.
    I have tried to modify existing script and my outcome looks like:
    I have checked and it looks like the script works. Maybe someone could check/advise if it is ok. Maybe some improvement could be made.
    Thanks in advance.
