Hinweis für Entwickler
  • Hi, is it to posiible to make an UDP call from the scipt (like HTTP call)?
    Documentation:
    RPC over UDP works in two directions:
    • RPC notifications can be sent from the Shelly device to a configured peer address
    Can only notification be send, or can I make any RPC UDP call ? (how?)
    Use case - WIZ Connected lights can be configured over lan with UDP messages only, It would be great to do it from Shelly.
    I want to avoid cloud or local server (like Home Assistant).
  • Can only notification be send, or can I make any RPC UDP call ? (how?)
    Only notification can be send (via websocket, MQTT or UDP)
