Shelly 1 Plus timeout with JSON list
Hinweis für Entwickler
  • I have a strange problem when calling an API providing some price data. It seems that when the response is normal JSON item then it works, but when it's a JSON list then I always get timeout error (-104). Is this some known limitation of Shelly http requests?
    This can be reproduces easily with this call:
    function handleResponse(result, error_code, error_message) {
    print(error_code);
    print(error_message);
    print(result);
    Shelly.call(
    "HTTP.GET",
    { url: "https://jsonplaceholder.typicode.com/posts/1/comments", timeout: 15, ssl_ca: "*" },
    handleResponse
    But this works as it doesn't return a list:
    Shelly.call(
    "HTTP.GET",
    { url: "https://jsonplaceholder.typicode.com/posts/1", timeout: 15, ssl_ca: "*" },
    handleResponse
    Einmal editiert, zuletzt von diyman (29. Januar 2023 um 11:22)
  • Limitation would produce a "limit exceeded" message. No idea what is causing the -104 error but this is probably related to the remote site.
    I have copied the entire JSON from the URLto a github Gist, this is working fine.
    https://gist.githubusercontent.com/eurich/d0288bc…2db237c2/hidden
  • The difference between your github response and the original response is that your response has text/html as Content-Type and the original has application/json (I have also done this same conversion to get this working).
