Widget does not support off-timer
  • Hi,
    I am using a Shelly Plus 1 for controlling our entrance gates. They just need a short on signal for activating, so in the app I set the off timer to 1 second. When I press the button, it sends the signal to the relay and then turns off again. That works great.
    However, when placing the device on the Shelly iOS widget for relays, this does not work, the blue circle that shows that the switch is on remains on.
    Would be great if that could be fixed in a future version.
    And if already at it, it would be great as well if the input state display (the green/red light) could be seen on the widget as well. In my case that one is fed by the switching input of the Plus 1, which is connected to a sensor showing whether the gates are open or not. In the app I can see now if the gates are open or closed, but on the widget that green/red light is not shown.
  • I have the same issue.
    The widget cannot be used if the Button Type is set to momentary with a turn-off timer set.
    How can it be solved??
    Thank in advance
    Gianmario
  • I have not found a solution yet. What could work is to use openHAB to integrate the device with Apple HomeKit and use that on the phone instead of the Shelly widget. But I have not gotten around to trying this yet ...
  • Is not tested
    but what if an action with auto off comes in the output on?
    http://localhost/relay/0?timer=1
    or
    http://localhost/relay/0?turn=on&timer=1
