I4DC scripting problem - Input.GetConfig
  • Hi,
    I'm scripting on a I4DC shelly.
    Script:
        print(JSON.stringify(Shelly.call("Input.GetConfig", {id: 3})));
    Returns: nothing!
    I was expecting something like:
        {"id":3, "name":"It worked", "type":"switch","invert":false,"factory_reset":true}
    If I try:
    print(Shelly.call("Input.GetConfig", {id: 3}));
    Returns:
        <foreign_ptr@40169664>
    Am I doing something wrong?
    Any help appreciated.
  • you're doing it wrong, Shelly.call is aynchronous. print doesn' reply anything because the answer from Shelly.Call is still in progress, thus nothing to print.
    This should work as expected because the print is inside the response function.
    Shelly.call(
        'Input.GetConfig', { id: 3 },
        function (response, error_code, error_message, ud) {
            print(JSON.stringify(response));
        null
