How to write a URL script for a Shelly Botton using a Shelly 1PM to turn a light on or off
Hinweis für Entwickler
  • Hi,
    My name is Terry and i am new to this and love the product.
    I am doing some testing with a Shelly 1PM and a Shelly Botton controlling a light. I wanted to turn the light on and off using the Shelly button.
    I know you need to put in the IP and some script telling it to turn on or off.
    Just can't find anything that can teach me the simple scripts I need.
    My home IP just say is 10.20.30.10 to 10.20.30.100
    My Botton is 10.20.30.15
    My1PM is 10.20.30.20
    Any help would be great.
    Thanks
    Terry
  • Hello Terry and welcome to forum
    You can create a webhook command to shelly button1 actions (I presume you mean to have Shelly Button1?) with following syntax:
    http://[Shelly1PM_IP]/relay/0?turn=toggle
    replace [Shelly1PM_IP] with relay IP address (10.20.30.20)
    That will toggle relay on/off with each press
  • Thanks for the welcome.
    Just tried it and it worked so thanks for the script.
    I assume I can add this to all the buttons just changing the IP address of each device in the script.
    I tried finding this line but couldn't. Do you have a link or documentation so I can try and learn more of the commands.
  • HI mitrossilis, welcome to the forum. :)
    Please get used to using correct terms straight away:
    The proposed solution or your question is not a script but http requests for webhooks (formerly called actions in Shelly of the 1st generation)
    Scripts are also optionally used with Shelly of the 2nd generation (= PLUS and Pro devices).
    Have a look here:
    HTTP-Request - overview
    Have a nice sunday.
