In-cable dimming with DImmer 2?
  • Good morning,
    I have a few lamps that have a physical in-cable dimmer and would like to connect them to our home automation via Shelly.
    However, I'd like to still be able to switch and dim the lamp via the in-cable switches, ideally with a slider for dimming. Similar to what the Shelly 1PM Plus can do with a physical switch, but additionally with dimming.
    I can see from the manual that the Dimmer 2 has two ports for physical switches, but how would dimming work with that? Only on button presses, or would it support a slider dimmer?
    Thanks for your help!
    Regards, Robert
  • It needs to be a push / retractive switch
    Ok, and you have that one connected to SW1? Is this with the short/ long push documented somewhere? I checked the manual, but it does not say anything about how the switches are to be operated and what is the purpose of SW1/SW2.
