Local variable storage
Hinweis für Entwickler
  • Hi,
    I have Shelly Plus 1PM.
    I did not find any answer from mJs scripting section of how to store variable locally so that I can recover it after reboot?
    I have installation that boots often and it is expected to be functional immediately after powerup. Including situations where wlan is not always available. I must store configurations into cloud because configurations are managed globally from cloud.
    brJani
  • Those data should be stored in the NVM (non volatile storage). Afaik is this feature at the todo list, but not yet implemented.
