Shelly UNI temperature in the smarthings app
  • Hello, Is there any way to display temperature and humidity value in smarthings app Shelly UNI devices? after integrating the UNI shell into smarthing, it will only be added to the app as a switch, this means that only ON/OFF can be controlled, no other functions. my idea was to create a virtual thermostat in smarthings and use Shelly UNI as a temperature and humidity sensor.
    Thank you for your response
    Einmal editiert, zuletzt von Gast10 (21. Dezember 2022 um 10:59) aus folgendem Grund: Code Tag deleted
