Problems with MQTT connection since 18.12.2022
  • Hi,
    I have been able to make a MQTT connection with hivemq broker example provided with mqtt-announce.js. For some reason the UI changed a day ago and ever since I have had problems with connecting the broker. I have booted many times but no connection is made. I don't know how to debug any further?
    br,Jani
  • Hi and welcome to the forum. :)
    Please try to reenter the password (of MQTT-broker) save and reboot.
  • Hi,
    I did once more did not help: Code states the same "not connected". I used BLE functionality here and it works. Anyway problem happens even with minimalistic mqtt code.
    // Scan options
    let scanOptions = {
    duration_ms: BLE.Scanner.INFINITE_SCAN, // Scan indefinitely
    active: false, // Use passive scanning
    interval_ms: 150,
    window_ms: 50,
    // Scan callback
    function scanCB(ev, res) {
    if (ev !== BLE.Scanner.SCAN_RESULT) return;
    // Get the address and signal strength of the beacon
    let addr = res.addr;
    let rssi = res.rssi;
    // Publish the beacon data to the MQTT topic
    //MQTT.publish("beacons", JSON.stringify({ addres: addr, signal: rssi }));
    //print(addr);
    // Start scanning
    BLE.Scanner.Start(scanOptions, scanCB);
    // Publish a message every 10 seconds to confirm that the code is running
    function mqttWatchdog(){
    let status = MQTT.isConnected();
    if(status){
    print("Running");
    MQTT.publish("beacons", "Running", 0, true);
    print("Running");
    } else {
    print("Not connected");
    Timer.set(2000, true, mqttWatchdog);
