Can I control multiple lights from 1 switch?
  • Good morning and it’s a pleasure to be part of this group. I hope my thread is in the right place.
    As you can probably tell I just started with Shelly and although i have a fairly good experience when it comes to home automation, I suck at wiring. Now let’s talk about the problem: my house is entirely automated, the only devices missing are the switches. I struggle because I don’t know which shelly relays I should buy! For example i have an open plan kitchen and in that room, I have 1 switch with 2 buttons. 1 button controls 4 LED lights in the living room and the other button controls 4 LED lights in the kitchen. Which Shelly should I use?
  • ArgentOS 14. Dezember 2022 um 09:41
    Hat den Titel des Themas von „Can I control multiple light from 1 switch?“ zu „Can I control multiple lights from 1 switch?“ geändert.
  • You'd need a Shelly with two relays such as Shelly Plus 2 PM or the older Shelly 25.
    Please note: The proper wiring needs to be behind the switch:
    Einmal editiert, zuletzt von Admin (16. Mai 2024 um 11:10) aus folgendem Grund: Bild wegen Markenrechtsverletzung gelöscht
