Somehow the dimmer won't stop calibrating. It's been doing so for the last hour, tried factory reset by pressing the small button on the device, any other suggestions?
Dimmer stuck in calibration?
Restless#Shadow#5200 -
30. Januar 2020 um 18:09 -
Erledigt
- Offizieller Beitrag
Hi @joostvd , welcome to the forum.
- shelly take away from 230V
- after a short time waiting, 230V again connect
- in the first 60 seconds, 5x switch on and off
Thats' a hard reset of the device.
Good luck.
I have the same problem. (dimmer 2 at firmware: 20200615-133340/v1.7.2@e39e9c86)
Calibration starts (at least I see the light is going on and then off ), but the calibration is stuck at 0%.
I retried several times with different bulbs. sometimes dimmer 2 is not accessible through web-ui anymore.
I did a factory reset. didn´t help, too.
this renders my shelby dimmer useless.
edit: I have bought 2 of those dimmers. Now I tried the other one:
calibrating switched from 0% to 50%. light went off. and then back to 0% and is stuck at 0% now. -
I asked support. They were super fast and detected that I made a mistake in the wiring.
Now it´s working perfectly well.
So what exactly was wrong with your wiring? I did wiring like it is dicribed in the manuell.
Dieses Thema enthält 9 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
