Pro 2 hangs after power failure
  • I have some troubles with a Pro 2:
    The device works fine using button (in momentary mode) also webhooks work as they should.
    After a power failure in my house Pro 2 hangs, if WLAN is not present while booting. The problem is, that after a power failure the WLAN-router needs some time to restart. Shelly Pro2 is of course faster and hangs with both relays are switched on and no reaction when reset-button is pressed.
    Any idea what´s th problem?
    Regards, Peter
  • What firmware-Version is installed?
    Can you let it boot normally if you briefly disconnect the Pro2 from the power supply and WLAN is available?
  • There ist the recent firmware version istalled: 0.11.4
    And, yes, the Shelly boots normally when WLAN is available.
    Einmal editiert, zuletzt von Gast10 (5. Dezember 2022 um 17:52) aus folgendem Grund: Fullquote of last answer deleted.
  • Unfortunately, I cannot reproduce the issue. What settings have you set under WiFi1 and WiFi2?
    Which at Power On default?
    Try WiFi1+2 with the same SSID/PW at the same time and see if there is any improvement
    These are the settings for relay type and power on. I tested restore last also, the effect is the same.
    and these are the current network settings:
    I use similar settings on serveral other gen 2 Shellies, but the problem occurs only on the Pro 2
