A script for comparing time to sunrise
Hinweis für Entwickler
  • Hello!
    I want a script that turns on a relay in the morning at 07:00 if it´s before sunrise.
    Is it possible to make such a script that compares a scheduled time with the time for sunrise?
    I don´t want the lights to go on if it´s already daylight outside.
  • After some thinking maybe I just create two schedules?
    One that turns the lights on at 07:00 and another one that disables that schedule at sunrise so the lights doesn´t go on.
  • Shelly.call("schedule.create",
    "id":9
    "enable":true,
    "timespec":"0 0 7 * * * SUN,MON,TUE,WED,THU,FRI,SAT",
    "calls":[{
    "method":"switch.set",
    "params":{
    "id":0,
    "on":true
    "enable":true,
    "timespec":"@sunrise * * *",
    "calls":[{
    "method":"schedule.update",
    "params":{
    "id":9,
    "enable":false
  • I had the same problem, and I've made a few scripts on the theme of tampering with schedules and they are kind of a workaround:
    schedule_delete_all:
    Shelly.call("schedule.deleteall",null,null,null);
    Shelly.call("schedule.list",null,function(res,error_code,error_msg,ud){print(JSON.stringify(res));},null);
    schedule_create:
    let i = 1;
    while(i < 5){
    Shelly.call("schedule.create",{"enable":true,"timespec":"0 0 0 * * SUN,MON,TUE,WED,THU,FRI,SAT","calls":[
    {"method":"switch.set","params":{"id":0,"on":false}}
    ]},null,null);
    i++;
    schedule_update:
    Shelly.call("schedule.update",{"id":1,"timespec":"0 0 5 * * SUN,MON,TUE,WED,THU,FRI,SAT","calls":[
    {"method":"switch.set","params":{"on":true,"id":0}}
    ]},null,null);
    Shelly.call("schedule.update",{"id":2,"enable":true,"timespec":"@sunrise * * SUN,MON,TUE,WED,THU,FRI,SAT","calls":[
    {"method":"schedule.update","params":{"id":1,"enable":false}}
    {"method":"schedule.update","params":{"id":3,"enable":true}}
    ]},null,null);
    Shelly.call("schedule.update",{"id":3,"timespec":"@sunset * * SUN,MON,TUE,WED,THU,FRI,SAT","calls":[
    ]},null,null);
    Shelly.call("schedule.update",{"id":4,"enable":true,"timespec":"0 0 23 * * SUN,MON,TUE,WED,THU,FRI,SAT","calls":[
    {"method":"schedule.update","params":{"id":1,"enable":true}}
    {"method":"schedule.update","params":{"id":3,"enable":false}}
    ]},null,null);
    Shelly.call("schedule.list",null,function(res,error_code,error_msg,ud){print(JSON.stringify(res));},null); //valfri
