Schedule not working reliably
  • Hello everyone,
    I have a PRO 1 PM that switches the controller of my floor heating.
    When I use the on/off switch in the app, I can get the controller to activate and deactivate.
    When I use the Schedule however, I noticed it does not switch on or off. I checked the log, and discovered that on some days it does switch, and other days it doesn't. It appears to be random.
    I have installed the latest firmware update. AndcI really need that timer to be working.
    Please help. Winter is coming.
    Regards,
    Peter
  • debaggerbak 20. November 2022 um 13:12
    Hat den Titel des Themas von „Schedule not werking reliably“ zu „Schedule not working reliably“ geändert.
  • Code
    {"jobs":[{"id":1,"enable":true,"timespec":"0 5 22 * * SUN,MON,TUE,WED,THU,FRI,SAT","calls":[{"method":"Switch.Set","params":{"id":0,"on":true}}]},{"id":2,"enable":true,"timespec":"0 58 5 * * SUN,MON,TUE,WED,THU,FRI,SAT","calls":[{"method":"Switch.Set","params":{"id":0,"on":false}}]}], "rev":9}
    yesterday evening it did not activate. This morning it did deactivate.
    Thanks,
    Peter
  • can you please provide the corresponding screenshots of the schedules from the app or home.shelly.cloud? Thanks
    What firmware is installed? latest stable 0.11.4 or 0.12.0-beta2?
  • Firmware appears to be 0.11.4. Schedule is simply on at 22.00h, off at 06.00h. Sometimes it works, sometimes not. I can post the screenshot, but it won’t tell you anything else. It is completely random.
    Thanks,
    Peter
