Suggestion for improvement: Variables in cloud
  • Suggestion for improvement:
    Add variables (that would work in scenes in IF or THEN) that user could add, rename and set themselves in the cloud, please.
    Example: In configuration set a variable (example temperature) that I will use in different scenes, but if I change it, auto changes in all the scenes.
    In configuration I set variable name:
    "high_temp"=23
    "low_temp"=20
    "myvariable"=0
    IF variable name "high_temp"<temperature in Shelly H&T THEN turn on device1
    but also:
    IF temperature in Shelly H&T (in bed room)<22 THEN variable name "myvariable"=1
    or
    IF device1 is on AND device2 is off THEN variable name "devices"=1
    2 Mal editiert, zuletzt von Billy-sk (9. November 2022 um 14:23)
  • Billy-sk 9. November 2022 um 14:25
    Hat den Titel des Themas von „Variables in cloud“ zu „Suggestion for improvement: Variables in cloud“ geändert.
