Shelly Dimmer 2 with 3-way switch (again) but with out of phase live
  • I know this topic has been talked about endlessly, but Im working on wiring a dimmer2 at the last position of a standard 3-way switch setup.
    The final 3-way switch is in a 4-gang box, so I figured I could steal a live from another switch, however, it turns out the live of every other switch in the box is on another (out of phase) circuit.
    Is there anything I can do here?
    I noticed there is a diagram where I can use neutral as the switch signal, can I hook the first switch's common to neutral in the 3-way circuit, the use the live from the other box?
  • why dont you put all switches in parallel connection.. and use only one switch setup?? that one you will have single phase across all three switches (same phase)
