Script for enabling schedule every evening
Hinweis für Entwickler
  • Can someone please give me some guide to a script that enables an existing schedule (no 1) every evening at 23:00?
    EDIT: Now I have the first part that reenables the existing schedule. Last thing is to complete the script with code so it runs every evening.
    Shelly.call("Schedule.Update", {
    "id": 1,
    "enable": true
    3 Mal editiert, zuletzt von DrJoshua (3. November 2022 um 15:08)
  • You could use a timer to ask a time server what time it is every minute and check if it is currently 23:00. I tried to do a test implementation below. You still have to insert your schedule enabling into the if clause. Also change the time zone accordingly, I currently set it to German time. There is also the problem with missing the target time because the polling intervall is exactly 60 seconds, which means we could possibly skip it. Good luck:
    [script] [/script]
    [script]let CONFIG = { [/script]
    [script] pollingInterval: 60 * 1000, [/script]
    [script] pollingUrl: "https://timeapi.io/api/Time/curre…e=Europe/Berlin", [/script]
    [script] hour: 23, [/script]
    [script] minute: 00, [/script]
    [script]}; [/script]
    [script]
    [/script]
    [script]Timer.set( [/script]
    [script] CONFIG.pollingInterval, [/script]
    [script] true, // Run periodically [/script]
    [script] function (ud) { [/script]
    [script] Shelly.call("HTTP.REQUEST", [/script]
    [script] { method: "GET", url: CONFIG.pollingUrl, timeout: 10 }, [/script]
    [script] function (res, error_code, error_msg, ud) { [/script]
    [script] print("errors-http-post:", error_code, error_msg); [/script]
    [script] if (error_code === 0) { [/script]
    [script] let parsedBody = JSON.parse(res.body); [/script]
    [script] print("Time server response:", res.body); [/script]
    [script] if (parsedBody.hour === CONFIG.hour && parsedBody.minute === CONFIG.minute) { [/script]
    [script] print("test"); [/script]
    [script] // do your thing [/script]
    [script] } [/script]
    [script] }, [/script]
    [script] null [/script]
    [script] ); [/script]
    [script]); [/script]
    [script][/script]
  • I just found out you can actually get the time from the device itself. This way you're not depending on some time server running. It works like this:
    [script][/script]
    [script]Shelly.call("Sys.GetStatus", [/script]
    [script] {}, [/script]
    [script] print("Current time is:", res.time); [/script]
    [script][/script]
  • Thanks for input!
    I think I made it more complex than it was. The result became a script like this:
    Shelly.call("schedule.create",
    "enable":true,
    "timespec":"0 11 21 * * SUN,MON,TUE,WED,THU,FRI,SAT",
    "calls":[{
    "method":"Schedule.Update",
    "params":{
    "id":1,
    "enable":true
