Connecting led and fan
  • Hi there.
    I want to connect a fan & Led lights (in two instances). Because of the wiring in the wallsocket of the first instance I can power the light and fan individually, in the second one I can power them only together (bathroom).
    Which shelly is able to work in wet rooms and can power fan/light together and which one can switch both individually on/off?
    I was thinking shelly 2.5 for the first instance and shelly 1 for second. Can those shellys power fan &leds? I read in the manual that you shouldn't connect a fan (inductive load) but see many that do.
    Thank you so much for replying!
    Kind regards,
    Edwin
