[SOLVED] PRO 4 PM - Get internal temperature in script ?
Hinweis für Entwickler
  • On the PRO 4 PM you can go to the status page on the display and see the internal temperature of the device.
    Has anyone found a way to get this value by scripting ?
  • gdslno 28. Oktober 2022 um 12:59
    Hat den Titel des Themas von „PRO 4 PM - Get internal temperature in script ?“ zu „[SOLVED] PRO 4 PM - Get internal temperature in script ?“ geändert.
