More outputs with one switch
  • Hello,
    I'm struggling with one thing for the past couple of hours. I'm trying to toggle two outputs on same shelly pro 4pm with one switch. I'm trying to do this via webhook but it doesn't work. When I use webhook to turn another output on or off on another shelly, its no problem. But can't seem to found a way on same device. Any ideas?
    I know i could combine this device on fuse after shelly device, but i'm trying to do it like this so i could switch on/off one of the outputs maybe with longer push of the button.
    Thanks for help.
  • theking 22. Oktober 2022 um 18:32
    Hat das Label von Shelly 4Pro auf Shelly PRO 4PM geändert.
