VSCode extension for Shelly Scripting?
Hinweis für Entwickler
  • Hi,
    with /rpc/Script.GetCode?id=1 i can dowload the Shelly Script #1. With PutCode i can write it to Shelly. I would like to use VS Code as an Editor and write the code to the shelly. Debug for example over websockets. Versioning in VSCode with git. Is there an extension for VSCode? Searched with alterco and shelly -> no results
    Thanks Thorsten
    Einmal editiert, zuletzt von scribere8146 (15. Oktober 2022 um 11:20)
  • so far I have not heard of any, but the idea is fantastic. Would be great if someone could do that.
