SW1 & SW2 Dimmer 2 with Shelly Wall double switch
  • Hi,
    I installed Dimmer2 on Shelly Wall double switch following the connection diagram of the shelly wall switch without N.
    So, the Red of the wall switch goes to L on dimmer, the other two on SW1 and SW2, and then the phase is in the other L and the lights are on the O.
    The setup is double button in the settings.
    Everything is working, however both buttons have the same functionality!!! It was supposed to be different, isn't it?
    Also the URL in actions is not working for any other device, unless it is for it self (for example http://localhost/light/0?brightness=25&transitiontime=1000)
    Any ideas?
    Thank you in advance
    John
  • Regarding ACTIONS, it is solved!
    The action was wrong, which i found it with trial and error... the correct url is:
    "http://[ip address]/light/0?turn=on&brightness=30 W"
