TRV hängt sich auf?
  • Ich habe mal zum Test einen TRV bestellt - will sehen ob er besser ist als die Homematic-Teile
    Wichtig ist mir insbesondere die Minimal einstellbare Ventilöffnung
    So ganz zufrieden bin ich mit dem Regelverhalten nicht - jetzt hat er sich aber irgendwie halb aufgehängt:
    In der Weboberfläche sehe ich nur noch das hier:
    Ein
    http://192.168.178.25/settings?
    liefert
    { "device":{"type":"SHTRV-01","mac":"8CF68110749D","hostname":"shellytrv-8CF68110749D","num_outputs":0},"wifi_ap":{"enabled":false,"ssid":"shellytrv-8CF68110749D"},"wifi_sta":{"enabled":true,"ssid":"Power-LAN","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt":{"enable":false,"server":"192.168.33.2:1883","user":null,"id":"shellytrv-8CF68110749D","clean_session":true,"max_qos":0,"retain":false,"update_period":60},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin","default_username":"admin"},"pin_code":"","name":null,"fw":"20220811-152343/v2.1.8@5afc928c","discoverable":true,"build_info":{"build_id":"20220811-152343/v2.1.8@5afc928c","build_timestamp":"2022-08-11T15:23:43Z","build_version":"2022081115"},"cloud":{"enabled":false},"coiot":{"enabled":false,"update_period":3600,"peer":""},"timezone":"Europe/Berlin","lat":��.������,"lng":�.������,"tzautodetect":true,"tz_utc_offset":7200,"tz_dst":false,"tz_dst_auto":true,"time":"13:58","child_lock":false,"clog_prevention":true,"display":{"brightness":4,"flipped":false},"hwinfo":{"hw_revision":"dev-prototype","batch_id":0},"sleep_mode":{"period":60,"unit":"m"},"thermostats":[{"target_t":{"enabled":true,"value":��.�,"value_op":�.�,"units":"C","accelerated_heating":false},"schedule":false,"schedule_profile":1,"schedule_profile_names":["Livingroom","Livingroom 1","Bedroom","Bedroom 1","Holiday"],"schedule_rules":["0600-0123456-23","2300-0123456-18"],"temperature_offset":0.0,"ext_t":{"enabled":true, "floor_heating": false},"t_auto":{"enabled":false},"boost_minutes":30,"valve_min_percent":�.��,"force_close":false,"calibration_correction":true,"extra_pressure":false,"open_window_report":false}] }
    bei
    http://192.168.178.25/thermostats/0
    kommt
    {"pos":�.�,"target_t":{"enabled":true,"value":��.�,"value_op":�.�,"units":"C"},"tmp":{"value":��.�,"units":"C","is_valid":true},"schedule":false,"schedule_profile":1,"boost_minutes":0,"window_open":false}
    die Firmware ist die Aktuelle
    Ist jemand was hierzu bekannt?
    Viele Grüße
