"timeout of 1000ms exceeded"
  • Good morning.
    I'm using a Shelly pro 4 PM to control a few Lamps on the outside of my property.
    The Shelly is sitting inside a house connection box and connected with an Ethernet cable from the Rack right beside it.
    I'm controlling the shelly via the MQTT protocol and Node-red.
    Now to the lamp logic.
    In my case, I'm using a 433MHZ remote controlling a Tasmotized Arduino. With this remote control, I can Turn on and turn off the outside lamps if I'm coming home or leaving them.
    To control these lamps I want to know which status the relais from the shelly have. so I'm grabbing the status via the Node-red "shelly gen 2" node via a 1000ms polling rate.
    With the status, node-red is residing whether it is turning the lamps on or of.
    But now the problem occurs.
    Often when I press the remote button the shelly is timing out with the following error (inside Node-red): "timeout of 1000ms exceeded".
    This error occurs for about 20 seconds an then it reconnects with: "connect EHOSTUNREACH 192.168.1.194:80"
    After this, it's working fine until it fails again.
    Do you guys have any idea what could be the problem?
    Thank you very much in advance!
