Edge switch - no dimming from switch
  • Hi all,
    Just wired my first shelly dimmer 2, with neutral, controlled by a single push button switch. I am having the following issue:
    - When configured in the default one-button mode, I can dim from the wall switch and double press to turn on at 100% brightness as expected. However, I cannot turn the light off from the switch.
    - When configured in edge mode, on/off behaviour works as expected. However, I lose the ability to dim from the wall switch.
    Everything works as expected when controlling through the shelly app / UI.
    Can you please help me out? Is the dimmer faulty?
    Thanks!
  • However, I cannot turn the light off from the switch.
    a short push button press should turn on/off the light. What happens when you press the button briefly?
    Question: is the device properly calibrated (Webinterface - Settings - Calibration)?
  • a short push button press should turn on/off the light. What happens when you press the button briefly?
    Thanks, the device is properly calibrated and operates with no issue in edge mode (well aside that I am unable to dim from switch in that mode). In single button more, it seems there is actually the following sequence, starting from the OFF status.
    Short press 1: nothing happens, light stays off
    Short press 2: dim up, to full brightness
    Short press 3: nothing happens, light still on
    Short press 4: dim down, until fully off
    Then the cycle repeats itself, so I am really puzzled.
