Shelly I4 double/long push delay
  • Hi there,
    I'm having the trouble that when you want to use the shelly I4 with momentary switches there's a delay after the press to use it again.
    Is there a way to adjust this delay time?
    It looks like the button is reactivated after the moment that the status of the button in the app (dot, double dot, stripe) is back to blank. This takes too long.
    This is very confusing especially when you pressed a wrong button for example for switching scenes.
    Note: this only occurs when you're using the shelly app itself. not when using mqtt.
    Maybe I missed something in the settings?
    Any help would be appreciated.
    Thanks
