returning wrong energy value
  • Shelly EM 50A clamp fw: 20210413-154159/v1.10.2-gb89901a
    Hi,
    My Shelly show what I supposed to be the correct values, except for energy 0 which vary now between 0.00 to 0.06Kw despite having a power running most of the time between 500w to 3.5Kw, it happen at once end of august.
    I try a factory reset but no change. (except loss of history)
    I used it with Home assistant +MQTT, My house Energy is not empty, but remain to a flat zero (not the message saying it is no data)
    could you recommend what to do next ??? any chance to make it work again ?
    is it the latest firmware for EM ?
    Thank you for your help.
    Einmal editiert, zuletzt von Pensee (13. September 2022 um 13:34)
  • I put a second brand new Shelly EM firmware v1.12, I have the same problem of energy 0 in the range 0.00 to 0.06Kw (like 1/1000 of what it should be).
    I am taking directly those values from listening MQTT, this is not a Home Assistant issue.
    Look like it change with firmware update (previously 1.03 was running with no problem)
    How do you deal with that ? anything you could do ?
  • 1 more year, update all shelly firmware and I still the same problem.
    MQTT return very small energy value despite consequent instant power.
    I could not have a reliable energy dashboard into HA, it's very annoying
    Help please !!!
