Is there a limit to the number of leds you can connect to a dimmer as long as you stay under the total of 200 watt ?
my dimmer died, at first i tested it on 6 * 6w leds(240v) worked fine, then i hooked it up in the living room with 16 * 6w, at first on off ok, then tried dimming and all of a sudden a buzzing from the dimmer and when it stopped the light was always on, factory reset no help, still always on.
I'm sorry to hear that.![]()
Perhaps, the sum of the individual switch-on peaks from the ledsmake a massive overload.![]()
Operational current: 0.25-1.1A a 6w led bulb is rated around 52mA .16 LED bulb on one output is killing the dimmer witch is rated to max 1A
