Shelly4PM script turn off after 6 minutes
Hinweis für Entwickler
  • Hello there,
    I am trying to write a method that turns off a switch after 6 minutes. But I am failing.
    Can you help me out what am I missing? also my aproach is correct? My sintax is following a the common practice? Most of it is from code snippet so I hope so:)
    I know shelly has a built in timer for that, but I would love to know a little bit better these scripts.
    Thanks!
