Difference in H & T in same room on two devices
  • Hi,
    I have two brandnew Shelly H&T, installed and connected to the network of choice. I read both of them in the exact same spot, and they both give quite a different temperature and humidity reading. The difference in T is about 4C and the difference in humididy is about 7%.
    If I compare this with my 'normal' HT device, I get a quite different reading. The difference between the Shelly's and the humidity reader is around 10%.
    Would there be a problem or is something wrong with the devices?
  • I have the same problem, but I have 4 devices all with different readings varies by up to 5C T and 10% H. I could do what was posted above and add an offset, but which one is correct or are they all wrong. Confusing !!
