Hi
I'm trying to "automate" the management of scheduling rules for an irrigation system via http:
With gen1 devices it were very simple:
http://192.168.33.127/settings/relay/0?schedule_rules=1000-0123456-on,1012-0123456-off,1400-0123456-on,1012-0123456-off,1404-0123456-off,1800-0123456-on,1012-0123456-off,1404-0123456-off,1810-0123456-off
Now, with gen2 devices should be easier, but I couldn't find the proper way:
For example, using schedule.Create, and @sunrise+1h59m and the web interface it seems to work:
"jobs": [{
"id": 1,
"enable": true,
"timespec": "@sunrise+01h59m * * SUN,MON,TUE,WED,THU,FRI,SAT",
"calls": [{
"method": "switch.set",
"params": {
"id": 0,
"on": true
"rev": 26
Alles anzeigen
but, if I use the rpc interface to add the schedule (previously I delete all using Schedule.DeleteAll):
http://192.168.33.127/rpc/Schedule.Create?timespec="@sunrise+01h59m * * SUN,MON,TUE,WED,THU,FRI,SAT"&calls=[{"method":"Switch.Set","params":{"id":0,"on":true}}]
I get
Also, the rpc interface for Schedule seems unstable... it's force me to factory reset the shelly plus 1 to get it work again... seems some kind of problem managing the scheduling list via rpc interface.
I'm open to suggestions ![]()
Thanks in advance !!!!
