HTTP.Request headers length too short
Hinweis für Entwickler
  • Hi,
    I try to make an HTTP.Request on my Home Assistant server, but after some times, I found my problem:
    Invalid argument 'headers': length should be less than 128!
    Because the generate token is very long !
    token.length ==>> 191
    Do you see a solution for this ? because I think that other application can have very long token.
    Thankyou
  • Can I have the screenshot?
    this is my test script ( with fake token of course :-) )
    And this, the log of shelly:
  • same problem here - but i "only" want to flip the state of a Shelly 1 PM Plus relais from a Shelly i4...
    as describled here https://shelly-api-docs.shelly.cloud/gen2/General/Authentication i need to use a two step request - this is the source of the second call:
    [script] [/script]
    [script] let url = '{"method": "GET", ' +
    ' "url":"http://admin:asdfasdf@10.2.0.215/rpc/Switch.Set?id=0&on=false", ' +
    ' "headers": {"Authorization": "Digest username=\\"admin\\", realm=\\"shellyplus1pm-7c87asdf48f0\\", nonce=\\"635asdf1b\\", cnonce=\\"OGI2MzMwYzFlMjVmZjg0MjasdfYzZDYwY2ZmZTFmOTY=\\", nc=00000001, qop=auth, response=\\"6df8a5a2328b4aasdfffbedf0f537eecf7b47f876c85ecf1b9f0597e9eb5ac33\\", algorithm=SHA-256"}' +
    print(url);
    Shelly.call( 'HTTP.Request',
    url,
    function callback(result, error_code, error_message, userdata)
    { //some further processing [/script]
    [script] }, [/script]
    [script] null); [/script]
    [script][/script]
    if i shorten the headers-parameter i can not fit everything needed in it. if i fit all needed information into the string it is longer than 128 chars.
    or do you know another way of controling in a script another shelly without HTTP? (without using MQTT to Homeassistant, ioBroker that calls then the other shelly)
    a older shelly (eg 1pm, led rgbw2) works fine with this code (basic auth):
    [script] [/script]
    [script]Shelly.call( 'HTTP.GET',
                    '{"url":"http://admin:asdfasdf@10.2.0.217/white/1?turn=off"}}',
    //some processing
                  null); [/script]
    [script][/script]
  • this is my test script ( with fake token of course :-) )
    Invalid argument 'headers': length should be less than 128! 10:29:29.522
    Did you find a solution?
    I'm stuck at the same problem, need to get some parameters from HA since I want to controll a heater mixer with the shelly. And the logic should be intentionally implemented within the shelly to eliminate overheating of the floor if HA is not available
