Switch to set 100%
  • Hello,
    Is it possible to configure a defined brightness when using the physical switch to turn on a light on the Dimmer 2?
    I have Dimmer2 modules in bedrooms with switches on the walls connected to the Dimmer2. I am wanting those physical switches to always set the brightness to 100% when the light is being turned on. Pressing again to turn off the light should still turn the light off and holding for dimming should also continue to work.
    Basically a script to set the light to 100% only if the light was off and the physical switch was pressed. Is this possible?
  • double click is your friend, it will tur on the device with 100% brightness.
