MQTT connection details
  • Hi.
    I have 15 shellies all connected to a (local) mosquitto broker. One of them (a Plus 1PM) won't connect.
    They all use the same credentials.
    I don't think it is an issue with the device because connecting it to "test.mosquitto.com" does work :rolleyes:
    I don't see anything in the mosquitto log so I was wondering if there is any way to have more details about a failure to connec or something on the Shelly side.
    Thanks.
    Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
  • If you want to try and debug the UDP traffic, have you already checked your router for the settings that apply to all your Shellies? I have an outbound NTP only rule for my Shellies for example, with my last setup I noticed I forgot to do *all* the settings for all the devices.... ;)
