test and usage of KVS
Hinweis für Entwickler
  • Hi,
    I test the last beta (0.11beta3) on shelly 1 plus.
    For one of my project I test the new KVS and I don't understand why my var "out_the_call" is undefined in my log:
    My code:
    If you have one idea please :-)
    Thank you.
  • Shelly.Call is asynchron, so the print at the end is executed before the kvsGet() has finished.
    you can validate this by adding a delay (Timer).
  • Do you know if there is plan to make this call synchron like some other call ?
    IIRC it was synchronous at the beginning but was changed. If you'd like to control a bunch of rempote shellies via loop it is important that network latency and response for each device doesn't delay the script execution. So I doubt this will be changed back.
    and there are still "workarounds" like adding a timer (my example above) or moving the related code to the response function:
  • Ok thanks for your reply, I understand the need about async result.
    I will think about it, because timer seems to be a "crapy fix". perhaps move the code into response, but I wouldlike get the value to use it into another function.. so I will think about.
    if a function require many KVS values, is very complicated to make clean code into response function....
    there is a solution to be notify when response is done ?
