Hi,
i have the problem that the relay turns itself randomly off, I can also see it in the messages section in the app.
The http://192.168.50.105/rpc/Shelly.GetStatus gives me the info that http is the source:
| source | "http" |
1. I checked that the Device-ID is 12 Digits: ok.
2. Today I turned cloud connection to off to be sure it does not come from the cloud.
3. Any other idea how to find out what caused the http command ?
FYI: I once turned the relay on/off depending on a temperature via Home Assistant, but I removed the scene in Home Assistant, so that should not be the source of the problem.
