Hi,
Please help me, because I don't know how to solve my problem.
I have:
- i4 (button mode)
- Shelly 2.5 as roller mode
- Dimmer2
- And a ton of other shelly products đ
I want:
- If I short press the button toggle the dimmer
- If I long press change the brightness of the dimmer
- If higher than 80% change to 5%
- If lower than 20% change to 100%
- If I double click toggle the roller
- If its above 90, go to 100
- If its 100 go to 0
- If its moving stop
What I tried:
- Short press solved with ddd (webhook) and its working
- I tired to solve the dimmer with scene, but its blinking now...
- Set to max
- If long pressed (condition type: once) and
- If the brightness is less then 20% (condition type: once)
- Turn on and set to 100%
- Set to min
- If the brightness is more then 80% (condition type: once)
- Turn on and set to 5%
- Set to max
What happend when I pushed long:
- The light started to blink (5% to 100% to 5%) and stop about after 10 minutes
My questions:
- How to solve the dimmer issue
- How to solve the roller scene
Thanks a lot!
Csaba
