mDNS discovery not working
  • Hello,
    I downloaded the bonjour SDK from apple but the device is not announcing itself via the mDNS protocol, what could be the cause of this?
    I do see other devices, so I guess it has nothing to do with the protocol being blocked.
    Kind regards
    Jasper
    Einmal editiert, zuletzt von Aspyryan (3. August 2022 um 13:01)
  • wihch firmware is currently installed on the Plus1PM?
    mDNS discovery is working fine for me (using my own tool from https://github.com/shelly-tools/ShellyDiscovery)
    {{ShellyPlus1-A8032ABCA8D8 _http._tcp local _http._tcp.local. ShellyPlus1-A8032ABCA8D8._http._tcp.local. _services._dns-sd._udp.local.} ShellyPlus1-A8032ABCA8D8.local. 80 [gen=2] 120 [192.168.178.186] []}
  • My bad for not supplying that information, here you go:
    Ill go check out your tool now, thanks!
    EDIT
    Ive tried the tool out and there too it does not give any records, maybe multicast is disabled on the network, otherwise I wouldn't know why it's not working.
    2 Mal editiert, zuletzt von Aspyryan (3. August 2022 um 15:26) aus folgendem Grund: tried the tool
  • the computer and the Shelly are located in the same subnet? Then multicast is probably blocked.
