Shelly PlugS as access point
  • If I use Plug S for the plug for the heat pump and want to use shedule for on/off, will the access point still be operational when the unit is off?
    My case is a Shelly Pro 1PM and a Shelly Pro 1 inside my pool pump housing and a heat pump outside. The heat pump uses 1.4-2.1 kw. If I use the Plus S for the heat pump, can I also use the access point for contact with the two Shelly Pro? Or would it be better to use a lan cabel?
    I also see another use for the Shelly Plug S, namely in my annex where I need a heater in the winter. It will be expensive to leave it on a lot so I want to control it. At the same time, I need to know the temperature inside the annex. Is there another Shelly unit that I would rather use for that?
    Hopefully,
    xlarge
