Shelly 1 - Garage door - Sommer Base + S9060
  • Hello,
    I want to connect a Shelly 1 to my garage door. Its a Sommer Base+ S9060.
    Is the following wire diagram correct?
    Is it true that in advance i can wire a magnet to the "SW" to check if the garage is open or closed?
    This is the manual of the garage door:
    https://www.gebruikershandleiding.com/Sommer-S-9060-…ing-844954.html
    On page 48 u can find the ceiling control unit circuit board
    Thanks!
    Einmal editiert, zuletzt von Warierke (26. Juli 2022 um 10:26)
    You mean i need to wire it to [9]?
    (I'm totaly new with this)
    Like this:
    2 Mal editiert, zuletzt von Warierke (26. Juli 2022 um 12:34)
  • Ok, thanks.
    The magnet would be wired like this right?
    (In example [9] would give permanent 24V)
    Or should i connect everything like this?
    With DIP switch 4 'ON'
    2 Mal editiert, zuletzt von Warierke (26. Juli 2022 um 13:29)
