AddOn module and temperature sensor
  • Hi,
    I am a brand new user and I just bought my first Shelly 1. After reading the instructions, I followed the steps closely to add the device to my home network and the app, but it's not sccessful.
    Now it is located under "hidden devices" as Offline / Pending connection.
    This device is brand new from the store and has never been connected to a network before.
    This happened the first time also so I have reset the device (5 times on/off sw) once before.
    Now I need some help because I just can't get any further.
    It's a 2.4 GHz network, I find the device and connect to it through the app. Then the AP network shows up on my wifi and I connect to that also. That is basically where I am at now.
    Regards
  • Hey Tirrazo
    Welcome to the Forum!
    did you take a look into our beginner's Tips? B2 and B6 may could help you
    Gast10
    11. August 2019 um 12:22
  • Hey Tirrazo
    Gast10
    Hi,
    Thank you - that helped me and I have now been able to add it to my account!
    I still can't get the temperature addon to work. We bought the addon and 1 temperature sensor to work with Shelly to measure temperature.
    After watching a video, this looked pretty simple. Just connect the cables and plug the addon with 5 pins into the serial port of Shelly while it's powered off.
    After powering it back o, the temperature is not visible in the app.
    Regards
  • Tirrazo 24. Juli 2022 um 14:45
    Hat den Titel des Themas von „Add new device“ zu „AddOn module and temperature sensor“ geändert.
