Shelly dimmer 2 under 75% not dimming
  • Hi,
    I have installed a Shelly Dimmer 2 with neutral, but my lamps still flicker below 75% and my dimmer does not work properly. lamps only work well above 75%.
    I have performed the calibration once, unfortunately this did not help.
    Would it help or can you also place a bypass at all if you have already connected the dimmer yourself with neutral?
  • Hi,
    Hello
    I would say that if you have a neutral then no need for bypass and might cause bypass to blow, have you checked that the lamps are dimmable as this could cause the issue with flickering.
    Matt
    Long-time home automation user.
    Head of Infrastructure for a B2C fulfilment centre.
  • I'd replace the bulbs, they are probably not dimmable.
  • suitable LEDs should have the dimmable sign on the package:
