Shelly plus 2pm : control two lights with a single switch/button
  • Hi
    I would like to reproduce a Step Relay behaviour i.e. control two light bulbs using only one Switch/button toggling between the following status :
    OFF-OFF
    ON-OFF
    OFF-ON
    ON-ON
    Using the "standard" one switch wiring diagram (Fig.5 on documentation) I can simulate all the status with an OFF-OFF between each change but I cannot have the Both Lights ON.
    Is there a way to reproduce a such behaviour?
    a possible solution could be (if possible) to send a toggle command to line 02 each time Line 01 is going from ON to OFF: Is it possible to be implemented?
    Thanks in advance
    Michele
