Control by MQTT
  • Hi,
    I have successfully connect my PLUS 1PM to my broker. (screenshot 1)
    All I want to do with this device is to activate and deactivate the relay by MQTT. All the other things I don't need. I will also never subscribe to any topic of this device.
    But I find as good as NO info about the topic and payload to do this.
    What I did found is that the topic should be: shellies/zwembad/relay/0/command and the payload simply on or off
    But this does not work.
    I do receive messages, but on completely different topic structures (screenshot 2)
    Do I need to do scripting to get started with MQTT controlling the device?
    Long story short: I have 1 (new) shelly device, what is the topic and payload to control the relay?
    Thanks
  • example for mosquitto_pub, message (-m) has to be JSON.
    mosquitto_pub -h localhost -p 1883 -u admin -P admin -t zwembad/rpc -m '{"id":124, "src":"zwembad", "method":"Switch.Set", "params":{"id":0,"on":true}}'
    Einmal editiert, zuletzt von Seven of Nine (17. Juli 2022 um 08:37)
  • Thanks,
    you have put me on the right way.
    The documentation is really confusing, but finally, with copy-past and a lot of testing I found the right topic and payload.
    Topic: zwembad/rpc ==> Where zwembad is the configured device name, don't forget the /rpc
    Payload: {"id":1, "src":"PFC100", "method": "Switch.Set", "params":{"id":0,"on":true} } ==> Where the first ID and SRC is something you choose, this comes back in the confirmation message.
    This can be closed
  • Thanks,
    This can be closed
    Hello,
    i am trying for some hours to do the same - switching the relay from MQTT, but it does not work.
    in my opinion i am using the same "order" as Nick - but the relay does not switch...
    is there anything else to configure on the ShellyPlus1PM?
    mosquitto_pub -t 'shellyTest/rpc' -m '{"id":124, "src":"shellyTest","method":"Switch.Set", "params":{"id":0,"on":true}}'
    with the http commands it works fine - both possibilites known to me work:
    http://192.168.2.xxx/relay/0?turn=on
    http://192.168.2.xxx/rpc/Switch.Set?id=0&on=true
    getting status infos like power and energy via mqtt works also fine only relay switching does not...
    thynk you for your help,
    Karl
  • Additional Information:
    Every Shelly device publishes and subscribes to specific preset topics, such as "command/switch:0" or "shellys/command..." You can control your Shelly devices by sending your commands to these specific topics. For "command/switch:0," your payload should consist of "on" , "off" or "toggle". All Shelly devices are listening to the "shellys/command" topic, so publishing commands there can be useful for executing bash commands like updating all devices, and nice other purposes.
    I initially searched for instructions on how to use them and stumbled upon this post. However, through some trial and error, I managed to make it work. I hope that anyone who finds themselves in a similar situation through a Google search can now save some time. ;)
    Einmal editiert, zuletzt von _[Deleted]_ (25. September 2023 um 08:41)
