Shelly EM not access via HA after username/password requested
  • Hi all,
    I`ve just attached yesterday my new Shelly EM (first Shelly) and after installing it and have access cloud and own shelly vía local ip, I'm not able to integrated with HA.
    This is HA version:
    Home Assistant 2022.7.2 Supervisor 2022.07.0F rontend 20220707.0 - latest
    And if i Go to configuration/devices/integration look for new integration Shelly and i put the correct IP local where Shelly is i put username/password and tell me that "Failed to connect".
    I had tried to join into password after deleting it access it shelly and the same result.
    Somebody with problems integration about shelly EM?. I would like to make vía HA instead HACS or via MQTT... What do you recomend me?
    Thanks in advance
    Snorre
    Devices should be auto discovered, if not press set up an other instance
    and enter ip address of device were it says host.
    you not have to enter a user name or password anywhere.
    Have you configured the device to the same network as HA
  • Yes,
    Shelly EM is in 192.168.68.102 and HA is in 192.168.68.50.
    Even if i test ping from HA to Shelly i have response.
    I put CoIot in raspberry ip like integration shows 192.168.68.50:5683. Put Shelly even in Discovery mode and when i add integation into HA Shelly and ask me from Host i introduce 192.168.68.102.... and nothing goes to... only a message window show me "Failed to connect" and as normal nothing exists in Devices, entities, etc.... Even Shelly integration doesn´t appear.
    Thanks for your reply
    Einmal editiert, zuletzt von soysnorre (12. Juli 2022 um 20:29)
