Shelly addon - more than temperature?
  • Hi,
    Being very new to Shelly, not being a electric expert... but a true amateur to all this...
    I read that the Shelly 1 now has an addon which can be used to connect a temperature sensor. Can the addon be used to connect different sensors as well? I would require humidity and air quality sensors.
    Would love to see this happening, so I can skip my extremely poor soldering skills and the need to flash tasmota on it. Any help very much appreciated.
  • Is it possble to make a Humidity sensor comatible with the GPIO adapter in the Temperature Sensor Addon for Shelly 1/1PM package?
    Maybe Shelly has plans to sell a Humidity sensor that is compatible with the GPIO-adapter in Temperature Sensor Addon for Shelly 1/1PM?
    If not, can you tell me if it is possible to connect any other compatible a Humidity sensor to the Shelly 1PM similar to how you can connect your recently announced Temperature Sensor Addon?
    The reason that I ask is that I have a (dumb) dehumidifier and been wanting to make smart and was wondering if could manage to do so with only a single all-in-one Shelly power-switch product that would support both electricity consumption measurement like the Shelly 1PM as well as be able to via its GPIO ports directly connect a humidity sensor like the Si7021 or AM2301 sensors which are for example sold by Itead for their Sonoff TH series.
    I know that would probably not work out-of-the-box your current version of firmware on the Shelly 1PM but could I maybe connect a Si7021 or AM2301 sensor to a Shelly 1PM and use third-party firmware like Tosmota?
    Sure I could use a Shelly 1PM and the separate wireless Humidity sensor and automate it, but I think that having humidity (and temperature) sensor like Si7021 or AM2301 directly wired to the board of a Shelly 1PM would make a nicer integrated product.
    Einmal editiert, zuletzt von Broken#Pond#4655 (16. Januar 2020 um 15:25)
    Hello Gamester17
    WELLCOME TO THE FORUM
    Around one week ago Dimitar (CEO of Allterco) announced that the AddOn will be able to connect DHT22-Sensors as well. At the moment I'm not sure if the FW is already prepared for this but it will come soon I guess.
    Grüße Bernd
    Mein "Smarthome":
