Issues with MQTT after firmware update v2.1.6
  • Anyone running into issues with MQTT on Shelly Motion after firmware update to 2.1.6? It just stops working entirely for me. I tried re-entering MQTT credentials and nothing. No authentication issues or anything from an MQTT perspective. Downgrading to 2.0.5 allows everything to start functioning again.
    EDIT: I did a bit more testing and my device goes unresponsive when attempting to change the MQTT server address from the current fqdn:port to ip_address:port.
    2 Mal editiert, zuletzt von npawelek (28. Juni 2022 um 17:42) aus folgendem Grund: Adding information
  • Same here. MQTT does not work at all after updating to 20220613-073803/v2.1.6@166b8318 firmware. Same behavior on both of my Shelly Motion devices.
    MQTT was working fine with out-of-the-box firmware but I didn't make a note of the version number :( I've reset both of my devices and am using the Shelly integration in Home Assistant instead of MQTT for now.
    How did you downgrade?
  • How did you downgrade?
    Grab the firmware from here: https://shelly-forum.com/index.php?shelly-firmware-archive/. Then you just need to use curl or something with your credentials to push the update to your device. Here's an example with httpie. You just need to set your variables for USER/PASS/ADDR respective of your setup.
  • The issue has been forwarded directly to the Allterco developers.
    Please be patient now.
    Thanks.
